Article ID : 00299094 / Last Modified : 01/09/2023Print
    How to use Amazon Alexa with BRAVIA TVs
    IMPORTANT: This article only applies to specific products, countries and/or operating systems.
    Basic Information on Amazon Alexa
    Alexa is Amazon's cloud-based voice service. You can use it to communicate with technology. Alexa Skills are voice-driven, Alexa Cloud Service capabilities which enable you to control select products through the Amazon® Alexa™ app that runs on Amazon Echo™ and Amazon Echo Dot™ devices. With this feature, you can use your voice to turn your TV on or off, change channels, control volume, and more.
    If your TV supports Amazon Alexa, one of the following apps will be in the Apps list. You cannot install these apps yourself.
    • TV Control with Smart Speakers
    • TV Control Setup with Amazon Alexa
    For more details, have a look at the information further down in this article.
    How to use Amazon Alexa on your BRAVIA TV
    Troubleshooting
    Attributions
    * Amazon, Echo, Alexa and all related logos are trademarks of Amazon.com, Inc. or its affiliates.
