Article ID : 00119115 / Last Modified : 06/07/2023Print
How do I perform a (soft) restart (reset) or Power cycle on Sony's Android TV?
    IMPORTANT: This solution applies to Android TVs. For details about how to reset a BRAVIA TV other than an Android TV, refer to: How to perform a power reset on a Sony television.
    Your BRAVIA TV runs the Android OS, which is also used in many smartphones and tablets. As with these devices, resetting your Android TV is an effective method to resolve some issues such as "the picture does not appear", "only sound is output", "the remote control does not work", or "the App is extremely slow."
    Perform the following operation to reset the TV.
    NOTES:
    • When an external USB hard disc is connected to the TV, disconnect the USB cable from the TV before resetting.
    • If TV is turned off, turn it on first and perform the following operation.
      1. Point the remote control to the illumination LED and press and hold the POWER button of the remote control for about 5 seconds until a message Power off appears.
        [1]: illumination LED
        [2]: Remote control POWER button
      2. TV reboots automatically. Wait for approximately one minute, and the TV will turn back on.
        If it does not reboot, press the POWER button on the remote control to turn on the TV.
      3. TV reset operation is complete.
        Make sure your issue has been resolved.
    NOTES:
    • If you unplug and plug in power cable, it may have same effect as the reset steps above.
      If the situation does not change after pressing the POWER button on the remote control, try the above. If you leave the TV with the power cord (mains lead) disconnected, the electricity that remains in the unit will be discharged. As a result, unnecessary data and error information in the memory will return to their defaults, and allow you to use the TV again normally.
      1. Turn off the TV.
      2. Unplug the television power cord (mains If the issue is not resolved, please try a Factory Data Reset.lead) from the electrical outlet.
      3. Let the television remain without power for 30 seconds.
      4. Plug the power cord (mains lead) back into the electrical outlet.
