How to set up your TV with the Amazon Alexa app
To connect your TV to the Amazon Alexa app, follow these steps:
- Go to the Home screen by pressing the HOME button on the supplied remote control.
- The next steps depend on your TV menu options:
- Option 1: If TV Control with Smart Speakers app or TV Control Setup with Amazon Alexa app is displayed on the Home screen, select one of them.
- Option 2 under Your apps, select See all — TV Control with Smart Speakers app.
- Option 3: Select Apps — TV Control Setup with Amazon Alexa app.
If your TV does not support the Amazon Alexa app, neither [TV Control with Smart Speakers] app nor [TV Control Setup with Amazon Alexa] app appears in the apps list.
Select the app that applies to your situation
Amazon and Alexa are trademarks of Amazon.com, Inc. or its affiliates.
