How to avoid image retention on OLED TVs
Organic EL displays (OLED) may experience image retention if an image is continuously displayed for a long period of time or the same image is repeatedly displayed. This is due to the characteristics of the materials used to achieve high-definition imaging. To protect your TV screen, avoid using images that may cause image retention.
Causes
- Content with black bars either on the top and bottom or the left and right sides of the screen, such as a letterbox or 4:3 screen
- Static images such as photos
- Video games that might have static content in some part of the screen
- On-screen menus, program guides, and channel logos
- Static content from apps
- On-screen tickers, such as those used for news and headlines
Functions that reduce image retention automatically
To protect the TV screen from image retention, we have equipped it with functions that automatically adjust the screen conditions. These functions automatically run according to your TV’s condition or you can run them manually.
Functions | How does it prevent image retention? |
Panel refresh | It automatically runs to adjust the uniformity of the TV screen after using it for long period of time. |
Panel calibration | It optimizes the screen or enhances the image in dark scenes. |
Pixel shift | It shifts the image of the TV screen after a certain amount of time. It runs automatically when you set this function to On. |
Screen saver | It activates when operations aren't performed for an extended period of time. Check this article for more details. |
Function to adjust the screen brightness | This function gradually reduces the screen brightness to protect the screen. Check this article for more details. |
How to prevent image retention
Check the following to reduce the risk of screen image retention:
- Follow the steps on how to reduce image retention or non-uniformity on the screen.
- Make sure there are no black bars or aspect ratio bars on the screen.
- On the supplied remote control, press the HOME button.
- Select
Settings.
- Select Display & Sound or Display.
- Select Screen.
- Select Wide mode.
- Select Wide zoom, Full or Zoom.
- Turn off the On Screen Display (OSD) and menus from the connected device.
- You can press the DISPLAY button on the supplied remote control to turn off the OSD or menu. Check your device manual for model-specific information.
- Avoid displaying static images with bright colors (including white), clocks, or logos on any portion of the screen.
- Set the Picture settings based on the ambient conditions.
Standard is recommended for home use and when watching programs that display station logos.
- Press the HOME button.
- Select
Settings.
- Select Picture.
- Select Picture mode.
- Select Standard.
