Article ID : 00173766 / Last Modified : 16/01/2026Print
What is Panel calibration?
    Generally, due to the characteristics of the materials used for organic EL displays to achieve high-definition imaging, the display is susceptible to screen image retention.
    Panel calibration is a function that optimises the screen and reduces image retention or enhances the image in dark scenes.
    Note: Panel calibration is performed automatically a few hours after the power is turned off with a remote control.
