Article ID : 00173729 / Last Modified : 23/12/2019
What is the "Panel Refresh" function?
    Panel Refresh will automatically run to adjust the panel uniformity of the TV screen after it has been in use for long periods of time.
    When you turn off the TV with the remote, a pop-up appears to prompt this function.
    You can also perform a refresh manually when  image retention is noticeable, or when you see the following message: "Panel refresh did not finish…"
    However, please do not perform this function more than once a year, as it may affect the lifespan of the panel.
    If you want to manually run the Panel Refresh function, please follow the steps below:
    1. Press the HOME button on the remote.
    2. Select  Settings.
    3. The next steps will depend on your TV menu options:
      • Select Display & Sound — Expert panel settings — Panel refresh.
      • Select Display — Expert panel settings — Panel refresh
    NOTES:
    • Due to the characteristics of the materials found in OLED displays, pixels may degrade and unevenness may become apparent on the TV screen.
    • Performing a Panel Refresh may take approximately one hour to complete.
    • A white line may be displayed on the screen during the refresh process, this is not a malfunction of the TV.
    • This function will only work when the room temperature is between 50 ºF and 104 ºF (10 ºC and 40 ºC).
