Article ID : 00255773 / Last Modified : 26/03/2026Print
How to reset your Sony soundbar or home theater system
    Learn how to reset your soundbar or home theater system.
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may be change.
    Select your model:
    If you cannot find your model:
    Follow the steps below to find your product manual.
    1. Go to the Sony Support website and enter your model name in the search bar.
    2. Select your model name to open the product page.
    3. You can find your product manual (Operating Instructions or Help Guide) just below the Manuals or Manuals & Warranty tab.
