Article ID : 00255773 / Last Modified : 10/04/2026Print
How to reset the soundbar or home theater system
    For how to reset the soundbar or home theater system, refer to the following:
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may change.
    • Not all models are sold in all countries or regions.
    HT-CT370 / HT-CT770
    Select another model
    1. Press on/standby button on the remote control to turn on the soundbar.
    2. Select AMP MENU button on the remote control.
    3. Press the (upper) or (lower) button repeatedly until SYSTEM appears, then press the enter button.
    4. Press the (upper) or (lower) button repeatedly until SYS.RST appears, then press the enter button.
    5. Press the enter button after displaying START.
    6. Disconnect the AC power cord (mains lead).
    If the issue is still not resolved, refer to the product manual.
