How to reset your Sony soundbar or home theater system
Learn how to reset your soundbar or home theater system.
Notes:- The reset method differs depending on the product.
- The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may be change.
HT-CT380 / HT-CT381 / HT-CT780
Select another model
- Press
on/standby to turn on the soundbar.
- Press MENU.
- Select SYSTEM by pressing the ↑ (upper) or ↓ (lower) button, then press ENTER.
- Select SYS.RST by pressing the ↑ (upper) or ↓ (lower) button, then press ENTER.
- When START appears on the display of the bar speaker, press ENTER. RESET appears on the display, and the settings will return to their initial status.
- When RESET disappears, disconnect the AC power cord (mains lead).
- Connect the AC power cord (mains lead), then press
If the issue is still not resolved, refer to the product manual.
