Article ID : 00255773 / Last Modified : 10/04/2026Print
How to reset the soundbar or home theater system
    For how to reset the soundbar or home theater system, refer to the following:
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may change.
    • Not all models are sold in all countries or regions.
    HT-CT260H / HT-CT290 / HT-CT291 / HT-G700 / HT-MT300 / HT-MT301 / HT-S2000 / HT-S200F / HT-SF200 / HT-SF201 / HT-S350 / HT-S400 / HT-SC40 / HT-SD35 / HT-SD40 / HT-X8500
    Select another model
    1. Press and hold the power and - (volume down) button on the soundbar for more than 5 seconds.
    2. Disconnect the AC power cord (mains lead), and then plug it back in.
    If the issue is still not resolved, refer to the product manual.
    Note for HT-S2000: After the reset, the device registration on the Sony | BRAVIA Connect app will be disabled. To register the device, delete the pairing information using your smartphone, and try the registration again.
    How to delete the pairing information
    The following descriptions are just examples. For details about the settings on the smartphone, refer to the smartphone manual.
    • Android smartphone
      1. Swipe down on the screen, and tap the Bluetooth icon to set the Bluetooth function to ON.
      2. Select SettingsDevice connection.
      3. On the Previously connected devices list, to the right of LE_xxxxx (the model name you want to delete), select the Settings icon.
      4. Select ForgetForget device.
    • iPhone / iPad
      1. Select SettingsBluetooth to set the Bluetooth function to ON.
      2. To the right of LE_xxxxx (the model name you want to delete), select the Information icon.
      3. Select Forget This Device.
    Hint: If LE_xxxxx (the model name you want to delete) and the device model name are displayed on the Previously connected devices list, delete both.
