Article ID : 00255773 / Last Modified : 10/04/2026Print
How to reset the soundbar or home theater system
    For how to reset the soundbar or home theater system, refer to the following:
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may change.
    • Not all models are sold in all countries or regions.
    HT-CT790 / HT-CT800 / HT-MT500 / HT-ST5000 / HT-ST9 / HT-RT5 / HT-XT2 / HT-XT3 / HT-NT3 / HT-NT5
    Select another model
    1. Press the HOME button on the remote control.
    2. Select Setup.
    3. Select Resetting.
    4. Select Reset to Factory Default Settings.
    5. Select the menu item you want to reset.
    6. Select Start.
    If the issue is still not resolved, refer to the product manual.
