Article ID : 00255773 / Last Modified : 10/04/2026Print
How to reset the soundbar or home theater system
    For how to reset the soundbar or home theater system, refer to the following:
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may change.
    • Not all models are sold in all countries or regions.
    HT-A9 / HT-A3000 / HT-A5000 / HT-A7000 / HT-X9000F / HT-XF9000 / HT-Z9F / HT-ZF9
    Select another model
    1. Press the HOME button on the remote control.
    2. Select SetupAdvanced Settings.
    3. Select Resetting.
    4. Select the menu item you want to reset.
    5. Select Start.
    If you cannot perform resetting using the Home menu:
    • HT-A9: Press and hold the power button on the control box for more than 10 seconds.
    • HT-A3000 / HT-A5000 / HT-7000 / HT-X9000F / HT-XF9000 / HT-Z9F / HT-ZF9: Press and hold the power button and - (volume down) button on the bar speaker for more than 5 seconds.
    If the issue is still not resolved, refer to the product manual or Help Guide.
