Article ID : 00267616 / Last Modified : 20/01/2026Print
    Screen Reader
    IMPORTANT:
    Blind or partially sighted? Contact Sony using Be My Eyes
    The Screen reader function works by vocalising information displayed on the TV screen, such as the programme guide or setting screen.
    Notes:
    • In order to use the Screen reader function, an Internet connection is necessary.
    • The Screen reader function is available only for focus points and some texts.
    • The Screen reader function is available only for some areas and languages.
    • Whether a given app is available with the Screen reader function depends on the specific app.
    • As of November 2020, YouTube™ is available with the Screen reader function. This specification may change without notice.
    • For eARC supported models, when Screen reader is activated, eARC mode will be set to Off.
    For how to activate or stop the Screen reader function, check one of the following depending on the TV setup:
