How to play back the content stored in a mobile device on the TV screen
IMPORTANT: For details on each mirroring connection method, refer to the manual of your TV. Depending on the model, some of the features listed below may not be available.
This solution will provide helpful information regarding the different ways that mirroring is supported by the TV and what devices can be used in each instance.
If using a wireless connection
Wireless Screen mirroring using Miracast technology:
The TV can be connected directly with a Screen mirroring and Miracast compatible device without the use of a cable or wireless router (or access point). A connection must be made by selecting Mirroring on the TV and on the source device. Refer to the list of Wi-Fi Certified Miracast devices found on the Wi-Fi Alliance website for more details.
NOTES:
- Connectivity with all Miracast compatible devices is not guaranteed.
- Apple devices do not support Screen mirroring (as of November 2014).
- All Xperia which supports Screen mirroring function. Sony does not guarantee other than Xperia.
What Xperia devices are confirmed for Screen mirroring connections?
For details on how to connect via Screen mirroring, visit the following FAQ:
How to use Screen mirroring.
One-touch mirroring using NFC:
Using one-touch mirroring with Near Field Connection (NFC) technology , just place your compatible smartphone to the one-touch remote control to be able to view exactly what is on your smartphone’s screen on the TV.
Refer to the website for a list of Sony devices compatible with one-touch NFC.
How to connect via Wi-Fi or an access point (Wi-Fi Direct):
You can use the Wi-Fi Direct function or an access point connection to display photos or play videos/music stored in the device on the TV.
For more details, visit the following FAQ:
How to set up and use the Wi-Fi Direct feature of the TV with Wi-Fi Direct capable device.
For Apple devices (iPhone/iPad), visit the following FAQ:
How to use the Wi-Fi Direct feature on the TV with an iPhone mobile device.
How to connect via Google Cast:
For Android TV models, you can use Google Cast to display photos or play videos/music stored in the device on the TV.
How do I use Google Cast on Sony's Android TV?
If using a wired connection
How to connect via MHL cable:
Using a Mobile High-Definition Link (MHL) cable , you can connect your smartphone to the TV to mirror what is seen on the smartphone screen. There is an expanding list of compatible devices that are supported using an MHL connection. For an up-to-date list, visit the MHL Consortium website.
* Be sure to use an authorized MHL 2 cable bearing the MHL logo.
How to connect via HDMI cable:
By using a Micro HDMI cable, you can connect your device to the TV and mirror what is seen on the device's screen.
NOTE: Not all smartphones have a Micro HDMI port. To see if your smartphone has a Micro HDMI port, check its specifications or operating instructions.
* Be sure to use an authorized HIGH SPEED HDMI cable bearing the HDMI logo.
