Voices are difficult to hear.
Sound is uneven.
Sound is high-pitched and loud.
The bass sound level is too low or too high.
For sound-related issues, if any of the issues in the following table occurs, adjust the equalizer setting according to the corrective action.
| issues | troubleshooting |
| Voices are difficult to hear. | Adjust the 125 Hz and 250Hz equalizer. |
| Sound is uneven. | Lower the 125 Hz equalizer. |
| Sound is high-pitched and loud. |
| The bass sound level is too low or too high. | Adjust the 125 Hz equalizer. |
How to set the equalizer:
- Press the ACTION MENU button on the remote control.
- Select Sound.
- Select Advanced settings.
- Select Sound mode related.
- Select Equaliser.
