Article ID : 00225041 / Last Modified : 10/08/2026Print
    How to care for your OLED/LCD TV
    Before you start
    To help prevent damage during normal household use, follow these precautions when cleaning your TV.
    • Before cleaning, turn off the TV and unplug it from the power outlet.
    • The screen has a special surface coating. Avoid touching it whenever possible.
    • Do not spray or apply detergent directly to the TV. Liquid cleaner may drip into the screen or exterior and may cause malfunction.
    • Do not spray chemicals, such as insecticides, onto the TV, and do not use solvents such as benzene or thinner. These substances may cause deterioration or peeling of the surface finish.
    • Avoid prolonged contact between the TV and rubber or vinyl materials, as this may cause deterioration or peeling.
    • If you plan to use a commercially available chemical or cleaning cloth, check with the manufacturer to confirm it is suitable for cleaning TVs.
    • Do not use a commercial available screen protective filter.
    Clean your TV
    • To help prevent damage during normal household cleaning, gently wipe the screen with a dry, clean microfiber cloth.
      For BRAVIA 9 II (XR90M2) - 85/75/65 inches models, refer to the following:
    • Gently wipe dust, fingerprints, or skin oil from the exterior using a dry, soft cloth, such as an eyeglass-cleaning cloth.
    • If ink from an oil-based marker gets on the screen, use a lightly dampened cloth with a synthetic detergent diluted with water (less than 1%), then wipe gently. Finish by wiping with a clean microfiber cloth.
    • Do not use detergent with abrasives such as a cleanser.
    • Avoid applying pressure while wiping the screen. On LCD TVs, pressure may temporarily affect the liquid crystal alignment and may appear as spots or marks. Turning the TV off and on may help the screen return to its normal appearance.
    • Wipe the printed areas (such as CH +, CH -, or HDMI2 labels) of the TV carefully using a soft dry cloth, as these areas may be damaged if scratched.
    • Because the space between the television and the stand (tabletop stand) is narrow, take care to avoid pinching your fingers. Using a cleaning tool with a handle may help.
    • Dust may collect near the ventilation opening. About once a month, gently vacuum these areas. Heavy dust buildup may affect performance.
    • To clean the remote control, soak a cloth in a neutral detergent diluted with water, then wring it thoroughly so no liquid drips. Wipe dirt from the remote control using the damp cloth and finish by lightly wiping the remote control with a dry cloth.
      Note: If battery fluid is leaking, remove the batteries and thoroughly wipe the battery compartment before inserting new batteries.
