How to wall mount your OLED TV (A1 series)
This article teaches you how to mount your OLED TV (A1 series) on the wall using the Wall-Mount Bracket (SU-WL450) sold separately.
For more detailed information and precautions about wall mounting, see the Wall-Mount Bracket Operating Instructions and the Installation Information (Wall-Mount Bracket) on the product page for the A1 series.
IMPORTANT:
For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
- Prepare necessary accessories and tools
- Install the bracket on the wall
- Mount the accessories to the TV
- Mount the TV to the wall
Wall mounting precautions
- Accessories
Consult the Operating Instructions from the Wall-Mount Bracket (SU-WL450) sold separately to confirm that you have all of the accessories listed there. - Tools
Prepare the tools below.
Electric drill Screwdriver Pencil Level guide Four or more screws of 8 mm diameter or equivalent One 5 mm diameter screw or equivalent
- Accessories
- Decide on the installation location.
Decide where to install the TV and bracket based on the diagram below.
[1] Screen centre point
Model Name Display dimensions Screen centre dimension KD-77A1 1,721 997 99 KD-65A1
1,451
834
93
KD-55A1 1,228 711 153
Allow for suitable clearance between the TV and the ceiling and protruding parts of the wall as shown below.
Unit: mm
Once you have decided on a location, place the bracket base against the wall and mark the installation point using your level guide and pencil. -
Select a Wall mounting style.
Choose between two installation methods: Standard, which creates space between the wall and the TV, or Slim, which brings the TV closer to the wall. With Slim mount, the TV feels integrated into the wall, allowing for a more streamlined appearance. The installation process differs depending on the mounting style.
IMPORTANT:
Regardless of which style you select, all cables must be connected to the TV prior to installation.Standard mount Slim mount *For KD-77A1: 162 mm
* For KD-77A1: 120 mm
Install the Base on the wall
Follow the steps below corresponding to the mounting style you selected.
Standard mount Slim mount - Install the Base Adaptor to the base using the screws that come with the bracket.
A: Base
I: Base Adaptor
J: PSW 4x10
- Install the base to the wall according to the diagram below using four or more screws of 8 mm diameter or equivalent (not supplied).
A: Base
I: Base Adaptor
A: Base
- Mount the metal wall-mount fittings that come with OLED TV (A1 series)
Necessary accessories
Screws (M4L12), metal wall-mount fittings (WM1/WM2)
Mount the wall-mount fittings and screws to the TV as seen below.
- Mount the screws and spacers that come with the bracket
The parts differ depending on if you selected Standard mount or Slim mount. Mount them according to the corresponding diagram below.
Standard mount Slim mount B:Pulley
C:Screw
(+PSW 6 x 20)
F:Belt
K:Spacer
(60 mm)
L:Screw (+PSW 6 x 50)
B:Pulley
C:Screw (+PSW 6 x 20)
E:Spacer (20 mm)
F:Belt
- Connect the power cord, HDMI cables, etc.
Make sure to connect the cables before installing the TV on the wall. You will be unable to connect the cables when the TV is installed.
- Mount the TV to the bracket base
Mount the pulley connected to the TV firmly into the base.
The mounting location differs depending on if you selected Standard mount or Slim mount. Install according to the corresponding diagram below.
Standard mount Slim mount B: Pulley
K: Spacer (60mm)
F: Belt
B: Pulley
E: Spacer (20mm)
F: Belt
- Tighten the belt and fix the TV to the wall
Take up the slack of the belt and attach it to the wall tightly. Then use a 5 mm diameter screw or equivalent (not supplied) and fix it to the wall.
Standard mount Slim mount F:Belt
F:Belt
Lastly, when you are able to confirm that the TV is fixed tightly to the wall, installation is complete.
Enjoy experiencing the beautiful images of the OLED TV as they come out of the wall.
- The wall should be capable of supporting a weight of at least four times the TV weight. Regarding the TV weight, refer to Wall mounting compatible information .
- Be sure to use the supplied screws and attachment parts properly. If you use substitute items, the TV may fall and cause bodily injury to someone or damage to the TV.
