Article ID : 00350003 / Last Modified : 17/06/2026Print
    How to use Android Auto and Apple Carplay
    Android Auto and Apple CarPlay make it easy to use your smartphone safely while driving by mirroring key features directly on your car's display. Both systems allow you to use certain apps from your vehicle's interface.
    Below, you'll find detailed instructions on how to set up, use, and troubleshoot both systems.
    Setting up Android Auto & Apple Carplay
    First, check if your car audio system supports Android Auto / Apple Carplay. You can check the car audio or infotainment system for logos (these may appear on the home screen or in the settings menu).
    1. To connect your phone, use a high-quality USB or lightning cable for a wired connection or enable Bluetooth and Wi-Fi for a wireless connection (if supported).
    2. Follow on-screen prompts to grant permissions for accessing data, contacts, and location. You'll need to grant permission to use certain features.
    Once connected, Android Auto / Apple CarPlay should appear on your car's display. Depending on your vehicle settings, you can enable it to activate automatically or by tapping the corresponding icon on the car interface.
    Using Android Auto and Apple CarPlay
    Both systems allow you to:
    • Navigate using apps like Google Maps, Waze, or Apple Maps.
    • Stream music and podcasts through Spotify, Apple Music, or other supported apps.
    • Make hands-free calls or send messages using Google Assistant or Siri.
    For voice commands, activate Google Assistant with "Hey Google" or Siri with "Hey Siri." Alternatively, use the voice command button on your steering wheel or infotainment system.
    What to do if Android Auto and Apple CarPlay or apps are not working
    Although it's a convenient system, the intersection between a phone, your vehicle, and third-party apps can sometimes cause challenges. Phones, apps and vehicle infotainment systems or car audio systems get regular updates to streamline performance.
    If you experience recurring issues, it often means the specific app, the car audio/infotainment system, or your phone needs an update.
    Car audio system doesn't detect my phone
    If Android Auto or CarPlay doesn't detect your phone, check the following:
    • For Android Auto:
      • Ensure your USB cable supports data transfer.
      • Your phone's Android version is 8.0 (Oreo) or later.
      • Verify Android Auto is enabled in your car's settings.
    • For Apple CarPlay
      • Confirm your Lightning cable works.
      • Ensure your iPhone's iOS version is 7.1 or later.
      • Check that CarPlay is enabled under Settings → General → CarPlay.
    Connection drops frequently
    • Ensure your phone's operating system and apps are up to date.
    • For wireless connections, check that Wi-Fi / mobile internet and Bluetooth are stable. If you're driving large distances, your phone might switch cell phone towers, which can cause a call to drop or halt.
    • Restart your phone and infotainment system.
    Audio Issues (no sound or distorted sound)
    • Ensure the correct audio output is selected in your car or app
    • Test another app to rule out issues with a specific service. Reconnecting your phone may also help.
    Car audio system freezes or responds slowly
    • Restart the infotainment system and your phone.
    • For Android Auto, clearing the app's cache/data may improve performance.
    Voice commands are not working
    • Check your internet connection, as both systems require active data for voice assistants.
    • Ensure the car's microphone is unobstructed, and reconfigure the voice assistant in your phone's settings if necessary.
