Xperia smartphones support the following accessibility features.
You can access them from [Settings] → [Accessibility] (some features may be excluded).
- These features are available on Xperia smartphones with Android 15.
- To check your Android version, go to [Settings] → [About phone] → [Android version].
- Some features might require app installation from Google Play, depending on the product and/or Android OS version.
What accessibility features help with vision and visibility?
TalkBack |
Use your device without looking at the screen by receiving spoken feedback. |
Select to Speak |
Tap specific items on your screen to hear them read aloud. |
Text-to-speech output |
Set the speech rate, pitch and language for text-to-speech output. |
Font size |
Make the text on the screen smaller or larger. |
Display size |
Make items on your screen smaller or larger. |
Bold text |
Use bold font to improve visibility. |
Colour correction |
Adjust how colours are displayed on your device. |
Colour inversion |
Change your display to use a dark background. |
Remove animations |
Reduce animations while using your device. |
Large mouse cursor/ |
Make the mouse pointer larger. |
High-contrast text |
Make text easier to read on your device. |
Extra dim |
Dim your screen beyond your phone's minimum brightness for more comfortable reading. |
Dark theme |
Change your display to a dark background. |
Magnification |
Zoom in or magnify to better see your device's screen. |
Audio Description |
Hear a description of what's happening on screen in supported movies and shows. |
Voice Access |
Speak to Voice Access and control your device hands-free. Note: Support varies depending on the product. |
What accessibility features help with hearing?
Live Transcribe |
Show speech as text on your screen to participate in conversations around you. |
Sound Notifications |
Your phone will always be checking for sounds you want to be notified about. |
Mono audio |
Integrate audio channels during playback. Combine stereo channels into one for single-ear listening. |
Audio balance |
Adjust the left and right audio balance. |
Caption preferences |
Set the caption size, style and language. |
Live Caption |
Live Caption detects speech on your device and automatically generates captions. Note: Support varies depending on the product. |
Flash notifications |
Flash the camera light or the screen when you receive notifications or when the alarm sounds. |
Hearing devices |
Set up and manage ASHA and LE Audio HAP hearing aids, cochlear implants, and other amplification devices. |
Hearing aid compatibility (HAC) |
The device supports magnetic coupling with hearing aids. If using a hearing aid with T-coil, turn on "Hearing aid compatibility" in Hearing devices, or you can also find it in the [Phone] app under [Settings] → [Accessibility]. |
Teletypewriter (TTY) |
You can use the Text Telephone (TTY) mode if connecting a teletypewriter via a 3.5mm audio jack. |
Real-time text (RTT) |
You can use Real-time text (RTT) to send text messages or generate captions over the phone. |
What accessibility features help to interact with your smartphone?
Accessibility Menu |
Control your device from a large on-screen menu. |
Switch Access |
Interact with your device using one or more switches. |
Touch and hold delay/ |
Adjust how long you need to touch the screen before it's registered as a 'touch & hold'. |
Time to take action (Accessibility timeout) |
Set how long temporary messages that ask you to take action stay on screen before disappearing. |
Click after mouse pointer stops moving |
Set the mouse cursor to take action automatically when the cursor stops moving for a set time. |
Navigation mode |
Choose between 3-button navigation and Gesture navigation. |
One-hand mode |
Make it easier to reach distant parts of the screen with one hand. |
Power button ends call |
Press your device's power button to end a call. |
Auto-rotate screen |
Automatically rotate your screen when you change your device's orientation (portrait or landscape). |
Vibration and haptics/ |
Enable vibration for ringing, notifications, and touch feedback. |
Smart call handling |
Handle incoming calls without having to touch the screen. |
Circle to Search |
Circle, highlight, scribble, or tap text/images on your screen to select them and search for them on Google. |
Swipe to invoke the assistant |
Swipe up from the bottom corner to invoke the digital assistant app. |
