Article ID : 00411507 / Last Modified : 14/09/2026Print
    Accessibility for Xperia Smartphone - For Android 17
    Xperia smartphones support the following accessibility features.
    You can access them from SettingsAccessibility (exclude some features)
    • These features are available on Xperia smartphones with Android 17 or later installed.
      • To learn which Android version your device has, find and tap SettingsAbout phoneAndroid version.
    • Some features might require app installation from Google Play depending on the product and/or Android OS version.
    What accessibility features help with vision and visibility?
    TalkBack
    You can use your device without looking at the screen by spoken feedback.
    Select to Speak
    You can tap specific items on your screen to hear them read aloud.
    Text-to-speech output
    You can set up speech rate, pitch and language for text-to-speech output.
    Font size
    You can make the text on the screen smaller or larger.
    Display size
    You can make the items on your screen smaller or larger.
    Bold text
    You can use bold font to improve visibility.
    Color correction
    You can adjust how colors are displayed on your device.
    Color inversion
    You can change your display to a dark background.
    Remove animations
    You can remove animation partly during operating your device.
    Text cursor blinking
    You can adjust the text cursor's blinking speed or turn off blinking.
    Note: This feature may not be supported on all apps or websites.
    Cursor & touchpad accessibility
    You can set the cursor size and click behavior when using an external mouse or touchpad.
    Note: This menu only appears if a mouse or touchpad is connected.
    Physical keyboard accessibility
    You can set the following keys when using an external keyboard:
    • Sticky keys
    • Bounce keys
    • Slow keys
    • Mouse keys
    Note: This menu only appears if an external keyboard is connected.
    Outline text
    You can make the text easier to read on your device.
    Extra dim
    You can dim your screen beyond your phone's minimum brightness so it's more comfortable to read.
    Dark theme
    Reduce blur effects
    This feature makes backgrounds and panels easier to see.
    Magnification
    You can zoom or magnify to see your device's screen better.
    Audio Description
    Hear a description of what's happening on screen in supported movies and shows.
    Voice Access
    Speak to Voice Access and control your device hands-free.
    Note:
    • Support varies depending on the product.
    • As of April 2025, only English, French, Italian, German and Spanish are available.
    What accessibility features help with hearing?
    Live Transcribe
    You can participate in conversations around you by showing speech as text on your screen.
    Sound Notifications
    Your phone will always be checking for sounds you want to be notified about.
    Mono audio
    You can integrate audio channel during playback.
    Audio balance
    You can adjust the left and right audio balance.
    Caption preferences
    You can set the caption size, style and language.
    Live Caption
    Live Caption detects speech on your device and automatically generate captions.
    Note: Support varies depending on the product.
    Flash notifications
    Flash the camera light or the screen when you receive notifications or when alarm sounds.
    Hearing devices
    Set up and manage ASHA and LE Audio HAP hearing aids, cochlear implants, and other amplification devices.
    Hearing aid compatibility (HAC)
    The device supports magnetic coupling for hearing aid device. In case you use your hearing aid device with T-coil, turn on "Hearing aid compatibility" in Hearing devices or you can also find it in the Phone app under SettingsAccessibility.
    Teletypewriter (TTY)
    You can use this Text Telephone (TTY) mode in case you connect a teletypewriter with 3.5 mm audio connectivity.
    Real-time text (RTT)
    You can use Real-time text (RTT) to send text messages or generate captions over the phone.
    What accessibility features help to interact with your smartphone?
    Accessibility Menu
    You can control your device from a large on-screen menu.
    Switch Access
    You can interact with your device using one or more switches.
    Touch and hold delay/
    Touch & hold delay
    You can adjust the amount of time before your tap on the screen becomes a touch & hold.
    Time to take action (Accessibility timeout)
    You can choose how long to show messages that ask you to take action but are visible only temporarily.
    Navigation mode
    You can choose between 3-button navigation and Gesture navigation.
    One-hand mode
    One-handed mode makes it easier to reach distant parts of the screen with your finger.
    Power button ends call
    You can press your device's power button to end a call.
    Auto-rotate screen
    You can rotate the screen automatically when you move your device between portrait and landscape.
    Vibration and haptics/
    Vibration & haptics
    You can turn on vibration for ringing, notifications, and touch.
    Smart call handling
    You can handle incoming calls without having to touch the screen.
    Circle to Search
    Circle, highlight, scribble, or tap text or images anywhere on your screen to select and search for them on Google.
    Swipe to invoke the assistant
    Swipe up from a bottom corner to invoke digital assistant app.
