The table below shows the accessibility features available on Xperia smartphones.
To access these features on your phone:
Find and tap [Settings] → [Accessibility].
Notes:
- These features are available on Xperia smartphones with Android 16 or later installed.
- To learn which Android version your device has, find and tap [Settings] → [About phone] → [Android version].
- Depending on the product and/or Android OS version, some features may be excluded. Others may require you to install an app from the Google Play Store.
What accessibility features help with vision and visibility?
TalkBack |
With spoken feedback, you can use your device without looking at the screen. |
Select to Speak |
You can tap specific items on your screen to hear them read aloud. |
Text-to-speech output |
You can set up the speech rate, pitch, and language for text-to-speech output. |
Font size |
You can make the text on the screen smaller or larger. |
Display size |
You can make the items on your screen smaller or larger. |
Bold text |
You can use bold font to improve visibility. |
Color correction |
You can adjust how colours are displayed on your device. |
Color inversion |
By reversing all the screen colours, you can change your display to a dark background. |
Remove animations |
You can remove some animations while operating your device. |
Cursor & touchpad accessibility |
You can set the cursor size and click behaviour when using an external mouse or touchpad. |
Outline text |
You can make the text easier to read on your device. |
Extra dim |
You can dim your screen beyond your phone's minimum brightness so it's more comfortable to read. |
Dark theme |
You can change your display to a dark background. |
Magnification |
You can zoom or magnify to see your device's screen better. |
Audio Description |
Hear a description of what's happening on screen while watching supported movies and shows. |
Voice Access |
Speak to Voice Access and control your device hands-free. Notes:
What accessibility features help with hearing?
Live Transcribe |
You can participate in conversations around you by showing speech as text on your screen. |
Sound Notifications |
Your phone will always be checking for sounds you want to be notified about. |
Mono audio |
You can integrate an audio channel during playback. |
Audio balance |
You can adjust the left and right audio balance. |
Caption preferences |
You can set the caption size, style, and language. |
Live Caption |
Live Caption detects speech on your device and automatically generates captions. |
Flash notifications |
Flash the camera light or the screen when you receive notifications or when an alarm sounds. |
Hearing devices |
Set up and manage ASHA and LE Audio HAP hearing aids, cochlear implants, and other amplification devices. *ASHA: American Speech-Language-Hearing Association |
Hearing-aid compatibility (HAC) |
The device supports magnetic coupling for a hearing aid device. If you are using a hearing aid with a T-coil, turn on "Hearing-aid compatibility" in the Hearing devices menu. You can also find it in the [Phone] app under [Settings] → [Accessibility]. |
Teletypewriter (TTY) |
You can use this Text Telephone (TTY) mode if you connect a teletypewriter with 3.5mm audio connectivity. |
Real-Time Text (RTT) |
You can use Real-Time Text (RTT) to send text messages or generate captions over the phone. |
What accessibility features help to interact with your smartphone?
Accessibility Menu |
You can control your device from a large on-screen menu. |
Switch Access |
You can interact with your device using one or more switches. |
Touch and hold delay / |
You can adjust the amount of time before your tap on the screen becomes a touch-and-hold action. |
Time to take action (Accessibility timeout) |
You can choose how long to show messages that ask you to take action but are visible only temporarily. |
Navigation mode |
You can choose between 3-button navigation and Gesture navigation. |
One-hand mode |
One-hand mode makes it easier to reach distant parts of the screen with your finger. |
Power button ends call |
You can press your device's power button to end a call. |
Auto-rotate screen |
You can rotate the screen automatically when you move your device between portrait and landscape. |
Vibration and haptics / |
You can turn on vibration for ringing, notifications, and touch. |
Smart call handling |
You can handle incoming calls without having to touch the screen. |
Circle to Search |
Circle, highlight, scribble, or tap text or images anywhere on your screen to select and search for them on Google. |
Swipe to invoke the assistant |
Swipe up from the bottom corner of the screen to invoke the digital assistant app. |
