The Picture Mode of my Android TV automatically switches to Vivid
If the Android TV™ automatically switches to Vivid after you changed the Picture Mode settings to Standard or Custom, check the following:
Make sure the Auto Picture Mode is Off
- On the remote control, press the HOME button.
- Select Settings.
- Under the TV category, select Picture & Display.
- Select Picture Adjustments.
- Select Auto Picture Mode.
- Select Off.
Make sure the Picture Reset Mode is Off.
- Select Settings.
- Under the System Preferences category, select Retail mode settings.
- Select Picture Reset Mode.
- Select Off.
Make sure DEMO mode is off.
If the issue isn't resolved after following the troubleshooting steps above, perform a factory reset.
