Article ID : 00155653 / Last Modified : 16/03/2022
How do I return to the TV broadcast screen or switch between inputs?
    There are three ways to return to the TV broadcast screen from the Home menu or switch between broadcasts (DTTV/satellite) and external inputs:
    1. Select Inputs from the Home screen, then select the icon for what you want to view.
    2. Press the INPUT button on the remote control, and select what input you want to view from the list.
    3. Press the TV button on the remote control.
    NOTE
    : The first method is only available when using a Touchpad remote control. (Not all TVs are supplied with a Touchpad remote control. For details, please refer to the manual supplied with the product.)
