Article ID : 00285267 / Last Modified : 24/11/2026Print
    Audio issues, such as imbalanced sound, volume adjustments, skipping sound, and noise
    Note: If the issue you are having is a volume difference between the left and right earbuds, refer to the There is a difference in volume between the left and right sides, or the bass (low frequency) sound is insufficient article.
    Select the appropriate headphones type or model for troubleshooting steps:
    Go to the Headphones Troubleshooting Guide top page
