Follow these steps to troubleshoot the issue:
Before you start
Radio interference will affect the Bluetooth communication between the headphones and playback device. The interference is likely to occur in a crowded place, near a store's cash registers, near a microwave, near traffic lights or automatic doors, inside a crowded train or in a station, etc. To avoid interference, move the headphones and speaker closer, or set the sound quality mode to Prioritize Stable Connection in the Sony | Sound Connect app.
Solution
Switch the sound quality mode to Prioritize Stable Connection.
- Open the Sony | Sound Connect app, and connect the headphones and the device via Bluetooth.
- In the My Device tab, select Device settings → Sound tab, and set the Bluetooth Connection Quality to Prioritize Stable Connection.
- The issue is resolved
- When the sound quality is high, the audio processing load will be heavy and may cause the audio to skip. By changing the Bluetooth Connection Quality setting, the load will be reduced and may resolve the issue.
- The issue is not resolved
- Go to the next troubleshooting step.
- Stop the Bluetooth connection to any device other than the headphones.
- The sound can skip when another device (smartwatch etc.) is also connected.
- Close all apps except the one you are currently using.
- The sound can skip when multiple apps are open at one time.
- Try the following procedure, then check if the issue is resolved.
- Set the headphones into the charging case, close the lid, wait for a few seconds, and then remove the headphones again.
- Reset (restart) the playback device.
Since the playback device may be temporarily malfunctioning, turn off the device once, and turn it on again. - Bring the headphones and the playback device closer together.
- The issue may have been caused by a temporary malfunction of the headphones or the playback device.
Reset the headphones.
Refer to the Help Guide or view the How to reset video:
- The issue may have been caused by a temporary malfunction of the headphones.
- Initialize the headphones and pair them with the playback device again.
- Initialize the headphones.
Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.Refer to the Help Guide or view the How to initialize video:
- Refer to the appropriate article to perform the pairing again: WF-C710N WF-C700N
- Check if the issue also occurs when connected with other devices.
- The playback device that was initially connected may be malfunctioning. Consult the manufacturer of the device.
- The headphones may be malfunctioning, and service may be required.
