Sound skips when using the LinkBuds S.
Before you start
Using the headphones in a crowded place such as on a train or busy road, nearby devices may interrupt Bluetooth communication and cause sound interruptions, interference, or noise. If the issue does not occur at home or somewhere with fewer nearby devices, then it is Bluetooth communication interference causing the issue, and not headphones.
Solution
Follow these steps to troubleshoot the issue:
- Switch the sound quality mode to Priority on Stable Connection.
Note: If the headphones are connected with LE Audio, switch back to Classic Audio only (conventional connection method) in the LE Audio connection setting for headphones, and switch the mode to Priority on Stable Connection.
- Open the Sony | Headphones Connect app, and connect the headphones and the device via Bluetooth.
- On the Sound tab, tap the
down arrow button on the right side of the Bluetooth Connection Quality, and select Priority on Stable Connection.
- The issue is resolved
- When the sound quality is high, the audio processing load will be heavy and may cause the audio to skip. By changing the Bluetooth Connection Quality setting, the load will be reduced and may resolve the issue.
- The issue is not resolved
- Go to the next troubleshooting step.
- Turn off the Speak-to-Chat function.
- Open the Sony | Headphones Connect app, and connect the device via Bluetooth.
- In the Sound tab, turn off the Speak-to-Chat function.
- The Speak-to-Chat setting was the cause of the issue. When Speak-to-Chat is set to ON, the headphones pause or mute the music being played and capture the voice of the person you are talking with to make it easier to hear. This may make you feel that the sound from the headphones is interrupted.
- Stop the Bluetooth connection to any device other than the headphones.
- The sound can skip when another device (smartwatch etc.) is also connected.
- Close all apps except the one you are currently using.
- The sound can skip when multiple apps are open at one time.
- Try the following procedure, then check if the issue is resolved.
- Set the headphones into the charging case, close the lid, wait for a few seconds, and then remove the headphones again.
- Reset (restart) the playback device.
Since the playback device may be temporarily malfunctioning, turn off the device once, and turn it on again. - Bring the headphones and the playback device closer together.
- The issue may have been caused by a temporary malfunction of the headphones or the playback device.
Reset the headphones.
Refer to the Help Guide or view the How to reset video:
- The issue may have been caused by a temporary malfunction of the headphones.
- Initialize the headphones and pair them with the playback device again.
- Initialize the headphones.
Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.Refer to the Help Guide or view the How to initialize video:
- Refer to the appropriate article to perform the pairing again:
- For Android: Pairing and connecting with an Android smartphone
- For iPhones: Pairing and connecting with an iPhone
- For other devices: How to pair Bluetooth headphones with a Bluetooth source device
- Check if the issue also occurs when connected with other devices.
- The playback device that was initially connected may be malfunctioning. Consult the manufacturer of the device.
- The headphones may be malfunctioning, and service may be required.
