Follow these steps to troubleshoot this issue:
- Use the touch sensor or button to adjust the volume.
- To increase the volume: Press the R (Right) unit button 4 times or more.
- To decrease the volume: Press the L (Left) unit button 4 times or more.
- The volume can be adjusted
- You can use the headphones to adjust the volume.
- The volume cannot be adjusted
- Go to the next troubleshooting step.
- Use the Sony | Sound Connect app to adjust the volume.
To adjust the volume using the Sony | Sound Connect app, move the slide bar next to the speaker icon in the My Device tab.
- You can use the Sony | Sound Connect app to adjust the volume.
- Adjust the volume on the connected device.
For details on how to adjust the volume on the connected device, refer to the device manual or support site.
Note: Depending on the connected device, the volume may not sync with the headphones. If you cannot get the desired volume by adjusting the headphones or device volume only, adjust the volume on both the headphones and the connected device.- The volume can be adjusted
- You may need to adjust the volume on the device in some situations.
- If the app has the volume settings, try adjusting the volume using those settings.
- The issue may have been caused by the app settings.
Reset the headphones.
Refer to the Help Guide or view the How to reset video:
- The issue may have been caused by a temporary malfunction.
Initialize the headphones.
Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.Refer to the Help Guide or view the How to initialize video:
- WF-C710N Help Guide (Initializing the headset to restore factory settings)
- WF-C700N Help Guide (Initializing the headset to restore factory settings)
- The headphones may be malfunctioning, and service may be required.
