What is Netflix calibrated mode and how to turn it on or off?
The Netflix calibrated mode on your Google TV™ or Android TV™ lets you experience picture quality close to a filmmaker's vision and intent. Follow the instructions below to turn it on or off.
Steps for Google TVs and Android TVs released after 2019
Applicable TV models
- 2025 models: BRAVIA 8 II (XR80M2), BRAVIA 5 (XR50)
- 2024 models: BRAVIA 7 (XR70), BRAVIA 8 (XR80), BRAVIA 9 (XR90)
- 2023 models: A95L, A80L_A83L_A84L, X95L, X90L series
- 2022 models: A95K, A90K, A80K_A83K_A84K, A75K, X95K, X90K_X92K_X93K_X94K (55-85), X90K_X92K_X90S_X94S (50), Z9K series
- 2021 models: X95J, Z9J, X90J_X92J_X93J_X94J (50-75, 100), A90J, A80J_A83J_A84J series
- 2020 models: A9, A8, ZH8, XH95 (55, 65, 75), XH95 (49, 85), XH90_XH92 series
- 2019 models: ZG9, AG9, XG95 series
Turn Netflix calibrated mode on or off
- Launch Netflix.
- On the supplied remote control, press the Quick Settings (
or
) button.
- Select Settings.
- Select Display & Sound.
- The next steps will depend on your TV menu options:
- Select Picture & Sound → Picture, then set Netflix calibrated mode to ON or OFF.
- Select Picture, then set Netflix calibrated mode to ON or OFF.
- If the Netflix calibrated mode is set to ON, the Picture mode settings become greyed out.
- If you want to select other Picture mode settings, follow steps 1 to 6 above to turn off the Netflix calibrated mode.
Steps for AF9 and ZF9 series (2018 models)
- Launch Netflix.
- Press the ACTION MENU button on the supplied remote control.
- The next step depends on how the menu is displayed on the screen.
Show displaying screens- When the menu is displayed on the bottom of the screen (Quick Settings):
- Select Settings.
- Select Picture.
- Set Netflix calibrated mode to ON or OFF.
- When the menu is displayed on the top of the screen (Action Menu)
- Select Picture adjustments.
- If you want to select other Picture mode settings, follow the steps above to turn off the Netflix calibrated mode.
