Article ID : 00374450 / Last Modified : 10/02/2026Print
Acoustic Auto Calibration isn't starting
    If the Acoustic Auto Calibration process stops and takes you to the settings screen, it means the app doesn’t have all the permissions it needs.
    Check the permissions for the Acoustic Auto Calibration app. Make sure the Microphone and Nearby devices permissions are turned on.
    For more information, refer to the article Adjusting the sound quality on a Google TV.
