Frequently asked questions about setting up the Smart B-Trainer and the associated app
This article discusses some frequently asked questions related to the setup of your Smart B-Trainer and the associated "B-Trainer for Running" app.
Is there a legally-imposed minimum age in order to use the Smart B-Trainer?
How to wear the Smart B-Trainer?
Where can I get the app, and which smartphones are supported?
Where can I find the current firmware version of the Smart B-Trainer, or the software version of the app?
How do I uninstall the app?
