Article ID : 00123164 / Last Modified : 12/07/2018Print
    Where can I get the app, and which smartphones/devices are supported?
    The Smart B-Trainer for Running app is available on Google Play and the App Store.
    GooglePlay AppStore
    It can be used on smartphones running Android 4.1 or later, or iPhones/iPods running iOS 7 or later.
    If you have difficulties installing the app, make sure your device is compatible and that you have Internet access.
