Article ID : 00226748 / Last Modified : 19/01/2026Print
Featured functions for the XG85, XG95, AG9 and ZG9 TV Series
    Let’s look at the main features of the XG85, XG95, AG9 and ZG9 TV Series.
    SUMMARY
    Android TV images
    How to enjoy apps and content on your Android TV™  Read more ▶
    Android TV offers thousands of movies, shows, and games from the Google Play Store, YouTube, Netflix, and your favourite apps.
    Voice recognition: how to search for content or operate your TV by using your voice  Read more ▶
    Android TV has a voice recognition feature. If your TV has a built-in MIC, you can ask it to search for content or operate the TV.
    Note:  For XG95, AG9, ZG9 Series, and in some regions and languages only.
    OK Google example
    How to use and customise the Home screen  Read more ▶
    From the Home screen, you can launch apps and settings, or find recommended content. You can also customise the screen to display the apps that you frequently use.
    How to switch the input source with your remote control  Read more ▶
    If you press the INPUT button on the remote control, you enter the Input source menu. From that menu, you can select the input source you want to display such as the TV, HDMI, or USB drive.
    On how to connect with other devices, you can also refer to the FAQs below:
    Quick Settings: how to change the TV settings while watching content  Read more ▶
    If you press the (Quick Settings) button on the remote control, the Settings menu is displayed.
    The Quick Settings menu allows you to make quick adjustments to picture and sound. Try altering the settings to match your preferences. You might change it depending on different content, such as movies, sports, or music performances.
    For more information about picture adjustment, refer to the FAQ below.
    How to adjust the Picture setting on my Android TV
    Casting videos and photos from a mobile device to your TV (Chromecast built-in)  Read more ▶
    Cast your favourite entertainment apps—movies & TV shows, music, games, sports and more—from your Android or iOS device, Mac or Windows computer, or Chromebook to your TV.
    For more information about Chromecast-enabled apps, refer to the site below.
    g.co/castapps
    For more about how to view mobile device content on your TV, refer to the FAQ below.
    How to display the content or screen of a mobile device on the TV screen
    Chromecast built-in - cast videos and photos from your mobile device to your TV
    Using Amazon Alexa
    If your TV supports Amazon Alexa and it's available in your country or region, you can use the Amazon Echo or Echo Dot to operate your TV.
    *Amazon, Echo, Echo Dot, Alexa and all related logos and motion marks are trademarks of Amazon.com, Inc. or its affiliates.
