If your Google TV™ or Android TV™ supports the Bluetooth Advanced Audio Distribution Profile (A2DP), you can connect Bluetooth audio devices such as headphones or speakers and enjoy TV sound through those devices. Check which TVs support A2DP or compatible Sony audio devices:
Check if your TV supports A2DP
You can check the applicable TV models on our support website by going to the Specifications section of your product page. If your model can use Bluetooth headphones, A2DP is displayed in the Bluetooth profile section.
Notes:
- We do not guarantee operation with all Bluetooth audio devices. Refer to the compatible model list for the devices that have been confirmed.
- You can also check the applicable TV models by confirming whether A/V sync is available on the TV Settings menu. If A/V sync is available, your TV model supports A2DP and can use Bluetooth audio devices:
- If your remote control has a Quick Settings (
or
) button, press the Quick Settings button → Select Settings → Display & Sound → Audio output → Bluetooth device settings → Check if A/V sync is available.
Note: If Bluetooth device settings is not shown, skip this step. - If your remote control does not have a Quick Settings (
or
) button, press the HOME button → and Select
Settings. The next steps will depend on your TV menu options:
- Select Display & Sound → Audio output → Check if A/V sync is available.
- Select Sound → Check if A/V sync is in the item.
Check the compatible model list
Choose your TV series. The models in the list are ones where we have confirmed the Bluetooth connection operations.
Notes:
- Bluetooth devices supporting A2DP that are not included in the compatible model list may work with your TV. However, we do not guarantee the functionality, audio latency, influence from the surrounding environment, etc.
- Some models in the list below are not available in some regions.
2026 TV series (other than BRAVIA 6 (A60))
The following TV models are confirmed to work with the following Bluetooth audio devices such as headphones, Neckband Speaker, and soundbars.
TVs:
- BRAVIA 9 II (XR90M2)
- BRAVIA 7 II (XR70M2)
- BRAVIA 3 II (XR30M2)
Note: BRAVIA 3 II (XR30M2) model does not support the SRS-NS7 (Neckband Speaker).
Headphones | Soundbars Home Theater Systems | Wireless Speakers (*1) | Neckband Speakers |
Float Run (WI-OE610) |
BRAVIA Theatre Bar 5 (HT-B500/BC50/BD50) |
LinkBuds Speaker (SRS-LS1) |
BRAVIA Theatre U (HT-AN7) |
- (*1):
- You can enjoy the Stereo Pair function by connecting your BRAVIA TV to two wireless speakers. (The SRS-RA5000 and SRS-RA3000 do not support the Stereo Pair function.)
- Audio delay, choppy sound, or a decrease in recognition rate on the remote control's microphone may occur when connecting the BRAVIA TV to multiple wireless speakers via the Party Connect function. (The SRS-RA5000, SRS-RA3000, SRS-XB100, and SRS-ULT10 do not support the Party Connect function.)
- (*2): Update the wireless speaker to the latest software (version after April 25, 2023).
- (*3): When connecting 2024 supported TV models to the SRS-NS7, the wireless transmitter (WLA-NS7) is not required.
2026 TV series (BRAVIA 6 (A60))
(BRAVIA 6 (A60) is confirmed to work with the following Bluetooth audio devices such as headphones, Neckband Speaker, and soundbars.
Headphones | Soundbars Home Theater Systems | Wireless Speakers | Neckband Speakers |
LinkBuds Speaker (SRS-LS1) (*1) |
BRAVIA Theatre U (HT-AN7) (*1) |
- (*1): For BRAVIA 6 (A60) TVs, if you experience audio and video synchronization issues when using a Bluetooth audio device, adjust the Bluetooth Delay setting and select the value that provides the best audio/video sync.
- (*2): When referring to the Help Guide for these soundbars about the Bluetooth connection between BRAVIA 6 (A60) and the soundbar, refer to the section title Listening to Music/Sound with the BLUETOOTH Function instead of Listening to Sony TV Sound with the BLUETOOTH Function.
- (*3): Update the wireless speaker to the latest software (version after April 25, 2023).
2025 TV series
TVs:
- BRAVIA 8 II (XR80M2)
- BRAVIA 5 (XR50)
- BRAVIA 3 (S30) (*Purchased in Mainland China and Europe)
- BRAVIA 2 II (S20M2)
Note: BRAVIA 3 (S30) and BRAVIA 2 II (S20M2) models do not support the SRS-NS7 (Neckband Speaker).
BRAVIA Theatre U (HT-AN7) (*3) |
- (*1):
- (*3): To enjoy the 360 Spatial Sound Personalizer feature, refer to this article: Which Sony audio products can use the exclusive features of BRAVIA TVs?.
- (*4): When connecting 2024 supported TV models to the SRS-NS7, the wireless transmitter (WLA-NS7) is not required.
2024 TV series
TVs:
- BRAVIA 9 (XR90)
- BRAVIA 8 (XR80)
- BRAVIA 7 (XR70)
- BRAVIA 3 (S30) (*Purchased outside mainland China and Europe)
- BRAVIA 2 (S20)
Note: BRAVIA 3 (S30) and BRAVIA 2 (S20) models do not support SRS-NS7 (Neckband Speaker).
| Float Run (WI-OE610) LinkBuds (WF-L900) LinkBuds Clip (WF-LC900) LinkBuds Fit (WF-LS910N) LinkBuds Open (WF-L910) LinkBuds S (WF-LS900N) ULT WEAR (WH-ULT900N) WF-1000XM4 WF-1000XM5 WF-1000XM6 WH-1000XM4 WH-1000XM5 WH-1000XM6 1000X THE COLLEXION (WH-1000XX) WF-C500 WF-C510 WF-C710N WF-SP800N WF-XB700 WH-CH710N WH-H910N WH-XB910N (*2) WI-1000XM2 WI-C100 WI-SP510 WH-CH520 WH-CH720N WF-C700N |
BRAVIA Theatre U (HT-AN7) (*4) |
- (*1):
- You can enjoy the Stereo Pair function by connecting BRAVIA with 2 wireless speakers. (The SRS-RA5000 and SRS-RA3000 do not support the Stereo Pair function.)
- Audio delay, choppy sound, or a decrease in recognition rate on the remote control's microphone may occur when connecting the BRAVIA with multiple wireless speakers via the Party Connect function. (The SRS-RA5000, SRS-RA3000, SRS-XB100 and SRS-ULT10 do not support the Party Connect function.)
- (*2): To use this feature, update the Headphones to the latest software (version after March 10, 2022).
- (*3): Update the Wireless speaker to the latest software. (version after April 25, 2023).
- (*4): To enjoy 360 Spatial Sound Personalizer, refer to the Which Sony audio products can use the exclusive features of BRAVIA TVs? article.
- (*5): When connecting 2024 supported TV models with the SRS-NS7, the wireless transmitter (WLA-NS7) is not required.
2023 TV series
TVs:
- A95L
- A80L_A83L_A84L
- A75L
- X95L
- X93L
- X90L_X91L
- X85L
- X82L
- X80L_X81L
- X75WL
- X64L_X70L_X74L_X75L
- X77L_X78L
Note: X64L_X70L_X74L_X75L and X77L_X78L series do not support the following models: SRS-NS7 (Neckband Speaker) / WH-1000XM6 / WF-C710N / WF-C510 / LinkBuds Fit (WF-LS910N) / LinkBuds Open (WF-L910) / LinkBuds Speaker (SRS-LS1) / BRAVIA Theatre Bar 6 (HT-B600/BD60) / BRAVIA Theatre System 6 (HT-S60) / ULT TOWER 9AC (SRS-ULT900AC) / ULT TOWER 9 (SRS-ULT900) / ULT FIELD 5 (SRS-ULT50) / ULT FIELD 3 (SRS-ULT30)
| Float Run (WI-OE610) LinkBuds (WF-L900) LinkBuds Clip (WF-LC900) LinkBuds Fit (WF-LS910N) LinkBuds Open (WF-L910) LinkBuds S (WF-LS900N) MUC-M2BT1 ULT WEAR (WH-ULT900N) WF-1000XM3 WF-1000XM4 WF-1000XM5 WF-1000XM6 WH-1000XM3 WH-1000XM4 WH-1000XM5 WH-1000XM6 1000X THE COLLEXION (WH-1000XX) WF-C500 WF-C510 WF-C710N WF-H800 WF-SP800N WF-XB700 WH-CH700N WH-CH710N WH-H810 WH-H910N WH-XB700 WH-XB900N WH-XB910N (*2) WI-1000XM2 WI-C100 WI-C400 WI-C600N WI-SP510 WH-CH520 WH-CH720N WF-C700N |
BRAVIA Theatre U (HT-AN7) (*6) |
- (*1):
(*4): When connecting an A95L series TV to these soundbars via Bluetooth, the volume may become low and unadjustable in rare cases. Update your TV to the latest software to resolve this issue.
(*5): When connecting an A95L series TV with the SRS-NS7, the wireless transmitter (WLA-NS7) is not required.
(*6): To enjoy 360 Spatial Sound Personalizer, refer to the Which Sony audio products can use the exclusive features of BRAVIA TVs? article.
2022 TV series (other than X74K_X75K and W8K series)
TVs:
- Z9K
- A95K
- A90K
- A80K_A83K_A84K
- A75K
- X95K
- X90K_X91K_X92K_X93K_X94K (55-85)
- X90K_X92K_X90S_X94S (50)
- X85K_X86K_X89K_85X80K
- X80K_X81K_X82K (43-75)
LinkBuds Speaker (SRS-LS1) | BRAVIA Theatre U (HT-AN7) (*4) SRS-NB10 |
- (*1):
2022 TV series (X74K_X75K series)
X74K_X75K series is confirmed to work with the following Bluetooth audio devices such as headphones and soundbars.
| Float Run (WI-OE610) LinkBuds (WF-L900) LinkBuds Clip (WF-LC900) LinkBuds Fit (WF-LS910N) LinkBuds Open (WF-L910) LinkBuds S (WF-LS900N) MUC-M2BT1 ULT WEAR (WH-ULT900N) WF-1000XM3 WF-1000XM4 WF-1000XM5 WF-1000XM6 WH-1000XM3 WH-1000XM4 WH-1000XM5 WH-1000XM6 1000X THE COLLEXION (WH-1000XX) WF-C500 WF-C510 WF-C710N WF-H800 WF-SP800N WF-XB700 WH-CH700N WH-CH710N WH-H810 WH-H910N WH-XB700 WH-XB900N WH-XB910N (*1) WI-1000XM2 WI-C100 WI-C400 WI-C600N WI-SP510 WH-CH520 WH-CH720N WF-C700N | BRAVIA Theatre Bar 5 (HT-B500/BC50/BD50) BRAVIA Theatre Bar 6 (HT-B600/BD60) BRAVIA Theatre Bar 7 (HT-A7100) BRAVIA Theatre Bar 8 (HT-A8000) BRAVIA Theatre Bar 9 (HT-A9000) BRAVIA Theatre Quad (HT-A9M2) BRAVIA Theatre System 6 (HT-S60) BRAVIA Theatre Trio (HT-A8) HT-A3000 HT-A5000 HT-A7000 HT-G700 HT-S2000 HT-S200F/SF200 HT-S350 HT-S40R HT-S400 HT-X8500 HT-X9000F/XF9000 HT-Z9F/ZF9 HT-A9 HT-AX7 |
LinkBuds Speaker (SRS-LS1) | SRS-NB10 BRAVIA Theatre U (HT-AN7) (*3) |
- (*1): To use this feature, update the Headphones to the latest software (version after March 10, 2022).
- (*2): Update the Wireless speaker to the latest software. (version after April 25, 2023).
(*3): To enjoy 360 Spatial Sound Personalizer, refer to the Which Sony audio products can use the exclusive features of BRAVIA TVs? article.
2021 TV series
The following TV models are confirmed to work with the listed Bluetooth audio devices such as headphones, Neckband Speakers, and soundbars:
TVs:
- Z9J
- A90J
- A80J_A83J_A84J
- X95J
- X90J_X91J_X92J_X93J_X94J (50-75, 100)
- X91J (85)
- X85J_X86J_X89J
- X79J_X80J_X81J_X82J
- X7x (*1)
Note for X7x series (*1): The WI-1000XM2, WH-1000XM4, WF-SP800N, and WF-XB700 models are the only Bluetooth devices supported with the X7x series.
Headphones | Soundbars Home Theater Systems | Wireless Speakers (*2) | Neckband Speakers |
| Float Run (WI-OE610) LinkBuds (WF-L900) LinkBuds Clip (WF-LC900) LinkBuds Fit (WF-LS910N) LinkBuds Open (WF-L910) LinkBuds S (WF-LS900N) MBH22 MDR-1000X MDR-100ABN MDR-1ABT MDR-EX750BT MDR-XB50BS MDR-XB650BT MDR-XB70BT MDR-XB80BS MDR-XB950B1 MDR-XB950N1 MDR-XB950BT MDR-ZX220BT MDR-ZX330BT MDR-ZX770BN MUC-M2BT1 SBH24 SBH56 SBH82D SBH90C ULT WEAR (WH-ULT900N) WF-1000XM3 WF-1000XM4 WF-1000XM5 WF-1000XM6 WF-H800 WF-C500 WF-C510 WF-C700N WF-C710N WF-SP800N WF-XB700 WH-1000XM2 WH-1000XM3 WH-1000XM4 WH-1000XM5 WH-1000XM6 1000X THE COLLEXION (WH-1000XX) WH-CH700N WH-CH500 WH-CH520 WH-CH400 WH-CH710N WH-CH720N WH-H800 WH-H810 WH-H900N WH-H910N WH-XB700 WH-XB900N WH-XB910N (*3) WI-1000X WI-1000XM2 WI-C100 WI-C300 WI-C400 WI-C600N WI-H700 WI-SP500 WI-SP510 WI-SP600N | BRAVIA Theatre Bar 5 (HT-B500/BC50/BD50) BRAVIA Theatre Bar 6 (HT-B600/BD60) BRAVIA Theatre Bar 7 (HT-A7100) BRAVIA Theatre Bar 8 (HT-A8000) BRAVIA Theatre Bar 9 (HT-A9000) BRAVIA Theatre Quad (HT-A9M2) BRAVIA Theatre System 6 (HT-S60) BRAVIA Theatre Trio (HT-A8) HT-A3000 HT-A5000 HT-A7000 HT-A9 HT-AX7 HT-G700 HT-S2000 HT-S200F/SF200 HT-S350 HT-S400 HT-S40R HT-X8500 HT-X9000F/XF9000 HT-Z9F/ZF9 | LinkBuds Speaker (SRS-LS1) LSPX-S3 SRS-RA3000 SRS-RA5000 SRS-XB100 SRS-XB23 SRS-XE200 (*4) SRS-XE300 (*4) SRS-XG300 (*4) SRS-XG500 SRS-XP500 SRS-XP700 SRS-XV800 SRS-XV900 (*4) ULT TOWER 10 (SRS-ULT1000) ULT TOWER 9AC (SRS-ULT900AC) ULT TOWER 9 (SRS-ULT900) ULT FIELD 7 (SRS-ULT70) ULT FIELD 5 (SRS-ULT50) ULT FIELD 3 (SRS-ULT30) ULT FIELD 1 (SRS-ULT10) | BRAVIA Theatre U (HT-AN7) (*5) SRS-NB10 |
- (*2):
- Audio delay, choppy sound, or a decrease in recognition rate on the remote control's microphone may occur when connecting the BRAVIA with multiple wireless speakers via the Party Connect function. (The SRS-RA5000, SRS-RA300, SRS-XB100 and SRS-ULT10 do not support the Party Connect function.)
- (*3): To use this feature, update the Headphones to the latest software (version after March 10, 2022).
- (*4): Update the Wireless speaker to the latest software. (version after April 25, 2023).
(*5): To enjoy 360 Spatial Sound Personalizer, refer to the Which Sony audio products can use the exclusive features of BRAVIA TVs? article.
2020 TV series
TVs:
- Z9H
- Z8H_ZH8
- A9_A9S
- A8_A8H
- XH95_X95H (49/85)
- XH95_X95H (55/65/75)
- XH90_X90H_X91H_XH92
- XH85_X85H_XH91
Note: If a 2020 model TV using the Android™ 8.0 OS is connected via Bluetooth to an HT-Z9F/ZF9 Soundbar, the sound may skip. To resolve the issue, update the TV to Android 9 OS. For details on how to perform the update, refer to this How to perform a software update article.
| LinkBuds (WF-L900) LinkBuds S (WF-LS900N) MBH22 MDR-1000X MDR-100ABN MDR-1ABT MDR-EX750BT MDR-XB50BS MDR-XB650BT MDR-XB70BT MDR-XB80BS MDR-XB950B1 MDR-XB950N1 MDR-XB950BT MDR-ZX220BT MDR-ZX330BT MDR-ZX770BN MUC-M2BT1 SBH24 SBH56 SBH82D SBH90C WF-1000XM3 WF-1000XM4 WF-H800 WF-C500 WF-SP800N WF-XB700 WH-1000XM2 WH-1000XM3 WH-1000XM4 WH-1000XM5 WH-CH700N WH-CH500 WH-CH400 WH-CH710N WH-H800 WH-H810 WH-H900N WH-H910N WH-XB700 WH-XB900N WH-XB910N (*2) WI-1000X WI-1000XM2 WI-C100 WI-C300 WI-C400 WI-C600N WI-H700 WI-SP500 WI-SP510 WI-SP600N | HT-A3000 HT-A5000 HT-A7000 HT-A9 HT-G700 HT-S200F/SF200 HT-S350 HT-S400 HT-S40R HT-X8500 HT-X9000F/XF9000 HT-Z9F/ZF9 | LSPX-S3 SRS-RA3000 SRS-RA5000 SRS-XB23 SRS-XE200 (*3) SRS-XE300 (*3) SRS-XG300 (*3) SRS-XG500 SRS-XP500 SRS-XP700 SRS-XV900 (*3) | SRS-NB10 |
- (*1):
- Audio delay, choppy sound, or a decrease in recognition rate on the remote control's microphone may occur when connecting the BRAVIA with multiple wireless speakers via the Party Connect function. (The SRS-RA5000 and SRS-RA3000 do not support the Party Connect function.)
2019 TV series or before
TVs:
2019 TV series:
- Z9G_ZG9
- A9G_AG9
- A8G_AG8
- XG95_X95G
- XG90_X90G
- XG83_X85G (KD-43/49)
- XG85_X85G_U8G (55/65/75/85) (*1)
2018 TV series:
- Z9F_ZF9
- A9F_AF9
- A8F_AF8
- XF90_X90F
- XF85_X85F_XF87
- XF83_X83F
- XF78_X78F
2017 TV series:
- A1 series
- X95E series
- XE93_X93E_XE94_X94E series
- XE90_X90E series
- XE85_X85E series
Notes:
- (*1) (*2): If an XG85xx_X85xxG_U8G Series (55/65/75/85) TV using the Android 8.0 OS is connected via Bluetooth to an HT-X9000F/XF9000 Soundbar, the sound may skip. To resolve the issue, update the TV to Android 9 OS. For details on how to perform the update, refer to this How to perform a software update article.
- (*3): 2017 and 2018 TV models and A8G_AG8 series do not support SRS-NB10 (Neckband Speaker).
- (*4): To use this feature, update the Headphones to the latest software (version after March 10, 2022).
- For the US, Canada, Europe, and mainland China: Updating to Android 7.0 Nougat is required.
| LinkBuds (WF-L900) MBH22 MDR-1000X MDR-100ABN MDR-1ABT MDR-EX750BT MDR-XB50BS MDR-XB650BT MDR-XB70BT MDR-XB80BS MDR-XB950B1 MDR-XB950N1 MDR-XB950BT MDR-ZX220BT MDR-ZX330BT MDR-ZX770BN MUC-M2BT1 SBH24 SBH56 SBH82D SBH90C WF-1000XM3 WF-1000XM4 WF-H800 WF-C500 WF-SP800N WF-XB700 WH-1000XM2 WH-1000XM3 WH-1000XM4 WH-CH700N WH-CH500 WH-CH400 WH-CH710N WH-H800 WH-H810 WH-H900N WH-H910N WH-XB700 WH-XB900N WH-XB910N (*4) WI-1000X WI-1000XM2 WI-C300 WI-C400 WI-C600N WI-H700 WI-SP500 WI-SP510 WI-SP600N | HT-A3000 HT-A5000 HT-A7000 HT-A9 HT-G700 HT-S200F/SF200 HT-S350 HT-S400 HT-S40R HT-X8500 HT-X9000F/XF9000 (*2) HT-Z9F/ZF9 | SRS-RA3000 SRS-RA5000 | SRS-NB10 (*3) |
Notes:
- Make sure your TV and other audio devices have the latest software update. You can install the latest software update for your TV model or other Sony audio devices from the Sony Support website. For how to update your TV, refer to the How to perform a software update article.
- Only one Bluetooth audio device can be connected to the TV at a time. It is possible to connect Bluetooth devices other than the Bluetooth audio device at the same time.
- The codec used when transmitting the Bluetooth audio device is SBC (Sub-Band Coding). (LDAC, AAC, aptX, eSBC, etc. are not supported.)
- Depending on the TV app used, or the Bluetooth audio device connected, some app operations performed from the Bluetooth audio device may not work. In such cases, use the TV remote control to operate the app.
- When connecting a BRAVIA TV with Bluetooth devices using a multipoint connection, a temporary audio delay or decrease in the recognition rate of the remote control's microphone may occur.
- If pairing with a Bluetooth audio device that supports LE Audio frequently fails, try disabling the LE Audio connection on the Bluetooth audio device. For instructions on how to change this setting, please refer to the Bluetooth audio device's instruction manual.
Related articles:
- How to connect Headphone to the Google TV or Android TV models via Bluetooth
- How to connect Sound Bar to the Google TV or Android TV models via Bluetooth
- In the event of issues, such as no sound coming out even when using applicable products, refer to the Troubleshooting for the Bluetooth connection with the audio device on Android TV FAQ.
Please accept Youtube cookies to watch this video
Access your cookie preferences below and make sure to switch on the Youtube cookie under the 'Functional' section.
Related Articles
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
