Accessibility features on Xperia Smartphones (Android 11 & higher)
Did you know that Xperia smartphones support a lot of accessibility features? They can help you use technology more easily.
You can access them in the settings menu under Accessibility. All these features are available on Xperia Smartphones that are running on Android 11 or higher.
Remember that they might differ a bit depending on your phone model and that some features might require you to install an app.
What are accessibility features that help with vision and visibility?
TalkBack |
You can use your device without looking at the screen via voice feedback. |
Select to Speak |
You can tap specific items on your screen to hear them read aloud. |
Font size |
You can make the text on the screen smaller or larger. |
Display size |
You can make the items on your screen smaller or larger. |
Bold text |
You can use bold font to improve visibility. (Android 12 or later) |
Colour correction |
You can adjust how colors are displayed on your device. |
Colour inversion |
You can change your display to a dark background. |
Remove animations |
You can remove animation partly during operating your device. |
Large mouse cursor |
You can make the mouse pointer larger. |
High-contrast text |
You can make the text easier to read on your device. |
Extra dim |
You can dim your screen beyond your phone's minimum brightness so it's more comfortable to read. (Android 12 or later) |
Dark theme |
Magnification |
You can zoom or magnify to see your device's screen better. |
What are accessibility features that help with hearing?
Live Transcribe |
You can participate in conversations around you by showing speech as text on your screen. |
Sound Notifications |
Your phone will always be checking for sounds you want to be notified about. |
Mono audio |
You can integrate audio channels during playback. |
Audio balance |
You can adjust the left and right audio balance. |
Caption preferences |
You can choose caption preferences for your device. |
What are accessibility features that help with interacting with your smartphone?
Accessibility Menu |
You can control your device from a large on-screen menu. |
Volume key shortcut |
You can press and hold both volume keys to start an accessibility feature. |
Accessibility Button |
You can start your accessibility apps or switch between accessibility apps. (Android 12 or later) |
Switch Access |
You can interact with your device using one or more switches. |
Touch & hold delay |
You can adjust the amount of time before your tap on the screen becomes a touch & hold. |
Time to take action (Accessibility timeout) |
You can choose how long to show messages that ask you to take action but are visible only temporarily. |
Click after the mouse pointer stops moving |
You can set the mouse cursor to take action automatically when the cursor stops moving for a certain amount of time. |
System navigation |
You can choose between 3-button navigation and Gesture navigation. |
One-hand mode |
One-handed mode makes it easier to reach distant parts of the screen with your finger. (Android 12 or later) |
Power button ends call |
You can press your device's power button to end a call. |
Auto-rotate screen |
You can rotate the screen automatically when you move your device between portrait and landscape. |
Vibration & haptic strength |
You can turn on vibration for ringing, notifications, and touch. |
