If you notice that the image displayed on the BBC iPlayer seems:
- a bit zoomed in
- not to fit the entire screen
- cropped, or the aspect ratio is wrong
then please change the display area settings of your television.
How to adjust TV display area settings
- Launch your TV app to watch broadcasted content. (If you don't, the display area setting will not be available)
- Go to your TV settings.
- Select Display & Sound.
- Open the Screen setting.
- Choose Display Area and select +1 (The default value is "normal").
