Select a topic to view the answer.
Getting Started
- Update your Blu-ray Player with the latest firmware, M43.R.0175 or later. You can find the link on the product page of your product.
- Use a Premium Hi-Speed HDMI cable or HDMI cable that supports 18 Gbps bandwidth to connect your Blu-ray Player and TV.
- Connect with Dolby Vision compatible UHD(4K)/HDR TV.
- Blu-ray Disc or Network Service Contents.
Connection
Connect the Blu-ray Player to your Dolby Vision compatible UHD (4K)/HDR TV using Premium High-Speed HDMI Cable or High-Speed HDMI cable that supports 18 Gbps bandwidth.
- Connect the HDMI cable to the HDMI OUT jack on the player.
- Connect the other end of the HDMI cable to the HDMI input jack for UHD (4K)/HDR or UHD (4K)/60p on your TV.
[A] Blu-ray player’s HDMI Out jack.
[B] TV’s HDMI IN jack.
In case you use an AV receiver or soundbar:
Verify that the AV receiver or soundbar is connected between the player and the Dolby Vision compatible UHD (4K)/HDR TV, and please ensure that the audio device is compatible with Dolby Vision signal transfer/switching.
[B] Audio device’s (AV receiver or soundbar) HDMI IN jack.
[C] Audio device’s (AV receiver or soundbar) HDMI OUT jack.
[D] TV’s HDMI IN jack.
For details please refer to the following:
How to play back in Dolby Atmos format audio using Multi Channel AV receiver or Sound Bar
Settings
- Verify that the setting of Dolby Vision Output is set to ON on your Blu-ray player:
- Press the HOME button on the remote control.
- Select Screen Settings.
- Set the Dolby Vision Output Setting to ON.
NOTE: There is no “Auto” setting and the default setting of Dolby Vision Output is OFF.
Verify that the HDMI setting for the HDMI jack on your TV corresponds to HDR.
- For Sony BRAVIA TVs:
- Select Settings.
- Select External inputs in the TV category.
- Select HDMI signal format and set to Enhanced Format.
- For other TV’s, please refer to your TV's instruction manual for this setting.
Additional Information
- When the Dolby Vision Output Setting is turned ON, the Video Settings and 3D Playback function will become unavailable.
- Content corresponding to Dolby Vision is output with HDR10 when Dolby Vision Output is set to OFF (Default Setting).
- When Dolby Vision is enabled, all content (included non-Dolby Vision encoded material such as HD Blu-ray Disc or non-HDR streaming content) will be played using Dolby Vision output. Please refer to the table below:
Dolby Vision Output Specifications
Dolby Vision Output Setting Content UHD (4K) / HDR TV corresponding to Dolby Vision UHD (4K) / HDR TV NOT corresponding to Dolby Vision SDR TV Dolby Vision: ON Dolby Vision Dolby Vision Output HDR 10 Output SDR Output converted from HDR to SDR HDR10 (High Dynamic Range) SDR (Standard Dynamic Range) SDR Output Dolby Vision: OFF
(Default setting)Dolby Vision HDR10 Output HDR10 Output SDR Output converted from HDR to SDR HDR10 SDR (Standard Dynamic Range) SDR Output SDR Output SDR Output
