How to update pre-installed apps on Google TV or Android TV (e.g., Netflix or YouTube)
If the Google Play™ Store app is set to Auto-update apps at any time (default), pre-installed apps on your Android TV™ or Google TV™, such as Netflix® or YouTube™ streaming services, are generally updated automatically.
Check the settings using the following procedure:
- On the supplied remote control, press the HOME or Quick Settings (
or
) button, depending on the model, then select
Settings.
- The next steps vary depending on your TV. Select the steps that best match your TV menu options:
- Select Apps → See all apps → Google Play Store (under SYSTEM APPS) → Open, then move the cursor to select your profile icon (an image or letter) in the upper-right or upper-left of the screen, and then select Settings → Auto-update apps → Auto-update apps at any time.
- Select
Apps → Google Play Store → Settings → Auto-update apps → Auto-update apps at any time.
- Select Google Play Store → Settings → Auto-update apps → Auto-update apps at any time.
- Steps from the Google Play Store profile.
