Article ID : 00113329 / Last Modified : 30/06/2021
How can I remove applications from my Sony's Android TV?
    Follow the steps below to uninstall an app on your Android TV™ device. Note that you can't uninstall a pre-installed app.
    1. On the supplied remote control, press the HOME button.
    2. Under Apps, select Google Play Store. You'll be asked to log in your Google™ account if you haven't logged in yet.
      • For Android TV's with Android™ 8.0 Oreo™ operating system, select Apps for Oreo Apps and then select Google Play Store.
    3. On the left pane, select My Apps.
    4. Select the app you want to uninstall.
    5. Select UNINSTALL.
      Select uninstall
    6. Select OK to confirm.
      confirm uninstallation
