What apps are available for my Android TV™ or Google TV™?
Select the item you want to check.
What apps are available for Sony's Android TV?
You can check what apps can be installed on Android TV from the Google Play Store.
- Google Play Store on the Android TV only displays apps that are supported by the TV, so apps that are not displayed are not supported at the moment. Not all apps for other Android™ devices such as smartphones can be used with the TV.
- Apps can be purchased through Google Play Store if you are logged in using your Google ID. You can also install apps you have already installed and paid for on your Android mobile devices for free if there is an Android TV equivalent.
There are two ways to determine what apps are available for an Android TV.
- Check using the Android TV HOME menu
If you already own an Android TV, you can select the Google Play store app from the Apps menu. You can then search through all of the listed apps.
Note: Home screens for TVs may differ depending on the models, regions and apps available.
- Check using a computer, tablet, or smartphone
Using a computer, tablet, or smartphone, visit the Apps for Android TV website for a list of the latest apps that are available for Android TV devices.
Note: Visiting the Apps for Android TV website, you can also see the Description and Reviews of the app before downloading.
What apps are available for Sony's Google TV?
- Check using the Google TV HOME menu
Select Apps tab in the HOME menu. To browse for apps, move up or down to find different categories. When you find a category you are interested in, move to the right to find items. You can also select a category from the App categories section.
Notes:- The Apps tab only displays apps that are supported by Google TV and those you can install. They may differ from apps for smartphones or tablets.
- You can easily search Apps by voice by pressing the Google Assistant (or MIC) button on your remote control, or search by using the on-screen keyboard. For details, refer to the How do I install applications on the Android TV or Google TV, and then confirm the apps installed? article.
- If you choose basic TV when you set up your Google TV, only pre-installed apps on your TV are available. You cannot install other apps. When you press the HOME button on the remote control, you can find all pre-installed apps on the Home menu. If you want to install other apps, you need to log in to your Google account and switch from basic TV to Google TV. To switch the TV to Google TV, from the Home screen, scroll to the Google TV banner, and select Set up Google TV.
Note: The website heading says Apps for Android TV, but both Google TV and Android TV can refer to this page.
How do I check all of the apps installed in Sony's Android TV or Google TV?
- Open the
Settings screen. How to access Settings
- Using the
Quick Settings button (For models released in 2019 or later)
- On the remote control, press the
(Quick Settings) button.
- Select
Settings.
- Using the HOME button
- On the remote control, press the HOME button.
- Select
Settings.
- Using the
- The next steps will depend on your TV menu options:
- Select Apps → See all apps. (Android 9 or later)
- Select Apps → Downloaded apps or System apps category. (Android 8.0 or earlier)
Please accept Youtube cookies to watch this video
Access your cookie preferences below and make sure to switch on the Youtube cookie under the 'Functional' section.
Related Articles
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
