Article ID : 00112546 / Last Modified : 23/09/2021
How do I install apps on my Sony's Android TV?
    Before you start
    • This article is for Android TV™ models only. If your TV is not an Android TV, refer to this other article for which apps are available on your TV.
    • You can only download apps that are compatible with TVs. These apps may differ from apps for mobile devices.
    • Check if the app you want to download is available for your Android TV.
    • Make sure your TV is connected to a network with an active internet connection.
    • You must have a Google™ account to download apps from the Google Play™ store.
    How to download and install apps
    1. On the supplied remote control, press the HOME button.
    2. Under Apps, select the Google Play Store.
      • On TVs with Android™ 8.0 Oreo™ operating system (OS), if you don't find it in the Apps Favorites section, select the Apps  icon, then select the Get more apps icon or Google Play Store.
    3. On the Google Play store screen, select the search  icon.
      • The search appears and the microphone icon turns red .
      • To search for the name of the app, say the name of the app using the Voice search feature of your TV.
      • If you want to use the on-screen keyboard, press the right arrow button to display it.
    4. Select the app.
    5. Select Install.
    How to launch an installed app
    1. Press the HOME button.
    2. Under Apps, select the app that you installed.
      • On TVs with Android 8.0 Oreo OS, select the Apps  icon to display the list of installed apps.
    How to uninstall an app
    2. Under Apps, select Google Play Store.  You'll be asked to log into your Google account if you haven't logged in yet.
      • On TVs with Android 8.0 Oreo OS, select  Apps and then select Google Play Store.
    3. On the left pane, select My Apps.
    4. Select the app you want to uninstall.
    5. Select UNINSTALL.
    6. Select OK to confirm.
    Note: You can't uninstall a pre-installed app.
