Article ID : 00154813 / Last Modified : 16/01/2026Print
    Blurry or after-image issues during moving scenes
    Blurry image or after-image issues may occur depending on the scene.
    To sharpen the image, set Random noise reduction to Low or Off with the following steps:
    1. Press the ACTION MENU button on the remote.
    2. Select Picture in the Display & Sound category.
    3. Select Advanced settings.
    4. Select Clarity.
    5. Select Random noise reduction.
    6. Select Low or Off.
