The picture is blurry when viewing digital broadcasts
If the picture of the television appears blurry when viewing digital broadcasts, changing the following picture quality settings may help to reduce the blur:
Lower the Digital noise reduction
- Press the ACTION MENU button on the remote control.
- Select Picture or Picture adjustment.
- Select Advanced settings.
- Select Clarity.
- Select Digital noise reduction and set to Low.
Adjust the Sharpness
- Adjust the Sharpness.
Reduce the Gamma value
- Select Brightness.
- Reduce the current Gamma value by 1.
