Article ID : 00146908 / Last Modified : 28/09/2017Print
The F-value on the aperture ring differs from the F-value displayed on the monitor
    The maximum F-value or aperture value depends on the focal length of the lens. The correct F-value or aperture value is the one displayed on the monitor. You cannot open the aperture wider than the maximum, even if you set a smaller F-value or aperture value using the aperture ring.
