Why does the brightness and colour of my recorded image look different when displayed on the monitor?
Check that the shooting settings of your camera are appropriately set.
NOTE: Some of the shooting settings such as Auto HDR are not applied to the Live View. Additionally, the shooting settings that can be applied vary depending the model.
You can reset the main shooting settings to the default settings.
- DSC-RX100M3
MENU -(Setup) - Setting Reset - Camera Settings Reset
- DSC-RX100M2 / DSC-RX100
MENU -(Setup) - Initialize - Rec mode reset
