Article ID : 00139699 / Last Modified : 25/02/2026Print
How to set or cancel a PIN code for your Android TV™ or Google TV™
    You can set a PIN code to enable Parental controls or Restricted Profile mode on your Android or Google TV. If you forget your PIN code, or want to cancel it, you can do so by following the steps in this article.
    Note: The method to set or cancel a PIN code is different for each feature and/or TV model. If you don't know your TV type, refer to this article: How to check if your BRAVIA TV is a Google TV™, Android TV™, or other TV.
    For select BRAVIA 2 / BRAVIA 3 / W8 / X7 series TVs
    Target models:
    BRAVIA 2 II (S20M2), BRAVIA 3 (S30), BRAVIA 2 (S20), W8x5_W8x6, W8L, X64L_X70L_X74L_X75L, X77L_X78L, W8K, X74K_X75K, W8, X7, and X74H_X75H series
    For select 2020 BRAVIA models and XH / Z8H / Z9H series TVs
    Target models:
    A8_A8H, A9_A9S, X9000H, XH80_X80H_X81H, XH81, XH85_X85H_XH91, XH90_X90H_X91H_XH92, XH95_X95H (49, 85), XH95_X95H (55, 65, 75), Z8H_ZH8, Z9H series
    Other Android TV models
