Article ID : 00104987 / Last Modified : 09/01/2015Print
I experience connectivity issues between the unit and my Samsung Galaxy S III smartphone. Is there a solution to this?
    The following procedure might solve the issue:
    • Start by disconnecting the USB cable between the unit and the smartphone
    • Then, close the Drive Link App on the Samsung Galaxy S III smartphone
    • Reconnect the smartphone to the unit using the USB cable
