Article ID : 00105141 / Last Modified : 12/01/2015
What can I do if I am having connectivity issues between my Sony Xperia smartphone and the unit when using the MirrorLink feature?
If you are experiencing MirrorLink connectivity issues between your Sony Xperia smartphone and the unit, you can try the following:
  • Disconnect and reconnect the USB cable between your smartphone and the unit
Or, if the problem persists:
  • Disconnect the USB cable, turn off your smartphone and turn it back on. Then, reconnect the USB cable between your smartphone and the unit
