IMPORTANT: This article only applies to specific products. Please check the Applicable Products of this article.
The Self Diagnostics option is a set of diagnostic features that are built into the Help or Customer Support menu of the TV to help customers diagnose and resolve basic setup and configuration issues.
The steps may differ depending on the model and software version. For details on how to start the Self Diagnostics test, consult the Help Guide or operating instructions of your TV. You can find them on the product page on this support website.
How to perform the Self Diagnostics
The following are examples of how to start the Self Diagnostics test. Choose your TV model type from the following.
For Android TV™ and Google TV™ models
If the issue persists
Try the following.
- Reset (restart) the TV.
- For Android TV and Google TV models: refer to the How to restart (reset) an Android TV / Google TV? article.
- For other TV models: refer to the How to perform a power reset on a Sony television article.
- Check and try Software updates. For information on how to update, refer to the How to perform a software update article.
- For pictures and sound symptoms: If you did not observe any problems with the test pictures and sound, the TV is functioning correctly. If you are experiencing picture or audio issues while using an externally connected device, verify the physical cable connection between the TV and the device as well as the external device settings.
