How can I turn on/off the Usage & Diagnostics information for Sony's Android TV?
You can choose whether you wish to help improve your Android TV by automatically sending diagnostic and usage data to Google. You can check your settings by going to:
[Home] > [Settings]* > [Personal - Usage & Diagnostics] > [Yes/No]
*For Android Oreo (OSV-O), the settings icon is located in the top right-hand corner.
Home
Settings
Settings: For Android Oreo (OSV-O), the settings iconis located in the top right-hand corner.
Yes/No
NOTE: The screenshots provided here are for reference only. The actual screen might differ slightly according to your country, model or firmware version.
