There is little or no sound from the portable speaker during Bluetooth connection.
- Make sure that the portable speaker and the connected audio device are turned on.
- Increase the volume level of the portable speaker and the connected device.
- Make sure that the connected device is playing music.
- Keep the speaker away from metal objects.
- If an audio cable is inserted to the portable speaker, the audio transmitted through the Bluetooth connection is not output. Disconnect any devices connected to the AUDIO IN port of the portable speaker.
- Make sure that the Bluetooth setting of the portable speaker and the audio input device are turned on.
- Pair the portable speaker and the audio input device again.
The troubleshooting steps listed above should resolve your issue. If you have completed all the steps and the issue is not resolved, service may be required.
